UART2 in KEAZ128 is causing problems
Question asked by Hugo Moran on Jan 23, 2019
Latest reply on Jan 28, 2019 by Kerry Zhou
Hello I have to use the 3 uarts that I have available, using UART0 and UART1 are working fine once I add UART2 i cannot run my application ( but I can debug it without any problem ).
UART2 initialization
UART0 and UART1
The only difference is the baudrate, but everything else is the same, but when I call UART2 I cannot run my application only if I am in debug mode.
I have seen something weird each time I change the priority back and forward I can run the application 1 time but after the first time it stops working again
