APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h: No such file or directory
wweir0618
when I run the code:nxpvt_codegen('face_detection_camera_main.m',config);
I meet a problem.as the follows:
../graphs/build-apu-nxp-sa-d/APU_CASCADE_OBJECT_DETECTION_LBP_4.hpp:8:97: fatal error:APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h: No such file or directory
but I find they are in the same folder.can everyone help me?thank you.
paulvlase
Hi wweir0618@outlook.com‌,
Can you attach the entire output of the build from Diagnostics Viewer window?
wweir0618
Hipaulvlase‌. Thanks for your reply. The entire output of the build is so long, as follows:
>> run_face_detection_camera_main
警告: Target IP Address is not set. Please set the global TARGET_IP_ADDRESS to the IP address of the board
> In run_face_detection_camera_main (line 13)
FFmpeg library already installed
Warning: coder.wref() is treated as coder.ref() when applied on a variable-sized array or a structure with
variable-sized fields.
Warning in ==> UMat_int32 Line: 97 Column: 75
Code generation successful (with warnings): View report
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB-Add-Ons\Toolboxes\NXP_Vision_Toolbox_for_S32V234\examples\apps\face_detection\codegen\exe\face_detection_camera_main>SET PATH=D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../msys32/mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../msys32/usr/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../msys32/mingw64/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Xarmv8-linux/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv8-eabi/i686-mingw32/bin;D:/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/../compilers/gcc-6.3.1-linaro-Earmv7-eabi/i686-mingw32/bin;D:\MATLAB\R2018b\bin\win64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\stefan\AppData\Local\Programs\Python\Python37;D:\Program Files (x86)\Calibre2\;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;D:\MATLAB\R2018b\runtime\win64;D:\MATLAB\R2018b\bin;C:\Users\stefan\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\stefan\AppData\Local\Programs\Python\Python37\;C:\Users\stefan\AppData\Local\Microsoft\WindowsApps;C:\Users\stefan\AppData\Roaming\MathWorks\MATLAB;
Current SDK ROOT is /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk
make[1]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[-]: skipping directory /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_offline/build-x86-gnu-windows-d
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[2]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
apu-kernel-getgraphs.mk: updating apu_cascade_object_detection_lbp_4_apu_process_desc_main.cpp
apu-kernel-getgraphs.mk: updating apu_cascade_object_detection_lbp_4_apu_process_desc_main.cpp_g++.d
  offline/X86 CX apu_cascade_object_detection_lbp_4_apu_process_desc_main.o
  offline/X86 LD apu_cascade_object_detection_lbp_4_apu_process_desc_main.exe  <=  apu_cascade_object_detection_lbp_4_apu_process_desc_main.o /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_offline/build-x86-gnu-windows-d/libacf_offline.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d/object_detection_kernelsacf.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d/optimization_kernelsacf.a
  offline/X86 executing apu_cascade_object_detection_lbp_4_apu_process_desc_main.exe
make[3]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
  apex/clang CX APU_CASCADE_OBJECT_DETECTION_LBP_4__MKDBstub.o
  apex/clang CX APU_CASCADE_OBJECT_DETECTION_LBP_4.o
make[3]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
  apex/clang LD APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.elf  <=  APU_CASCADE_OBJECT_DETECTION_LBP_4.o APU_CASCADE_OBJECT_DETECTION_LBP_4__MKDBstub.o /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d/libacf_target.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d/libapu_common.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d/object_detection_kernels.a /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d/optimization_kernels.a
  apex/clang READELF APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h
make[2]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[1]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[1]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[-]: skipping directory /d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/firmware/build-v234ce-gnu-linux-o
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/drivers/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/icp/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/dcu/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/frame_io/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/gdi/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/io/sdi/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/cam_generic/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/csi/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/fdma/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264enc/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/h264dec/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/jpegdec/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/sequencer/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/isp/viu/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/common/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/communications/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/log/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/oal/user/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[5]: Nothing to be done for 'all'.
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/utils/umat/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Nothing to be done for 'apu_graphs'.
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Nothing to be done for 'apu_graphs_link'.
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'all'.
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/acf_target/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apex/common/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_arithmetic/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'apu_graphs'.
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[7]: Nothing to be done for 'apu_graphs_link'.
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/arithmetic/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_color_conversion/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/color_conversion/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/apexcv_core/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_histogram/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/histogram/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_base_image_filters/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_base/image_filters/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_hog/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/hog/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_remap/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/remap/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_resize/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/resize/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/apexcv_pro_pyramid/build-apu-nxp-sa-d'
make[6]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[7]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[7]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[6]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[3]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[2]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/libs/apexcv_pro/image_pyramid/build-v234ce-gnu-linux-o'
make[2]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_object_detection_kernels/build-apu-nxp-sa-d'
make[4]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[5]: Entering directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[5]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[4]: Leaving directory '/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/kernels/apu/sample_optimization_kernels/build-apu-nxp-sa-d'
make[4]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[5]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[5]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[4]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/graphs/build-apu-nxp-sa-d'
make[3]: Entering directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
.C0_headdep.mk: updating nxpvt_CascadeObjectDetector_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_CascadeObjectDetectorLBP-cpp.C0.d
.C0_headdep.mk: updating tinyxml2-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoreader_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoreader-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoinput_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_videoinput-cpp.C0.d
.C0_headdep.mk: updating nxpvt_utils-cpp.C0.d
.C0_headdep.mk: updating nxpvt_umat_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_opencv_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imwrite_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imshow_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_imread_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_convertScaleAbs_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_resize_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_remap_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_peopledetector_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_peopledetector-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_interpolation_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_integral_image_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_image_filters_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_histogram_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_color_conversion_w-cpp.C0.d
.C0_headdep.mk: updating nxpvt_apexcv_arithmetic_w-cpp.C0.d
.C0_headdep.mk: updating gdc_pd_types-cpp.C0.d
.C0_headdep.mk: updating camera_input-cpp.C0.d
.C0_headdep.mk: updating main-cpp.C0.d
.C0_headdep.mk: updating surfCommon-cpp.C0.d
.C0_headdep.mk: updating pointTrackerCore-cpp.C0.d
.C0_headdep.mk: updating opticalFlowFarnebackCore-cpp.C0.d
.C0_headdep.mk: updating mwsurf-cpp.C0.d
.C0_headdep.mk: updating mwminiflann-cpp.C0.d
.C0_headdep.mk: updating mwhog-cpp.C0.d
.C0_headdep.mk: updating mwhaar-cpp.C0.d
.C0_headdep.mk: updating mwfreak-cpp.C0.d
.C0_headdep.mk: updating mwflann-cpp.C0.d
.C0_headdep.mk: updating mwfast-cpp.C0.d
.C0_headdep.mk: updating mwcascadedetect-cpp.C0.d
.C0_headdep.mk: updating mwbrisk-cpp.C0.d
.C0_headdep.mk: updating matchFeaturesApproxNNCore-cpp.C0.d
.C0_headdep.mk: updating features2d_init_mw-cpp.C0.d
.C0_headdep.mk: updating fast_score_mw-cpp.C0.d
.C0_headdep.mk: updating fastHessianDetectorCore-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main_terminate-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main_initialize-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main_emxutil-cpp.C0.d
.C0_headdep.mk: updating face_detection_camera_main-cpp.C0.d
.C0_headdep.mk: updating extractSurfCore-cpp.C0.d
.C0_headdep.mk: updating extractKAZECore-cpp.C0.d
.C0_headdep.mk: updating extractFreakCore-cpp.C0.d
.C0_headdep.mk: updating extractBRISKCore-cpp.C0.d
.C0_headdep.mk: updating disparitySGBMCore-cpp.C0.d
.C0_headdep.mk: updating disparityBMCore-cpp.C0.d
.C0_headdep.mk: updating detectMserCore-cpp.C0.d
.C0_headdep.mk: updating detectKAZECore-cpp.C0.d
.C0_headdep.mk: updating detectFASTCore-cpp.C0.d
.C0_headdep.mk: updating detectBRISKCore-cpp.C0.d
.C0_headdep.mk: updating cgCommon-cpp.C0.d
.C0_headdep.mk: updating agast_score_mw-cpp.C0.d
.C0_headdep.mk: updating HOGDescriptorCore-cpp.C0.d
.C0_headdep.mk: updating CascadeClassifierCore-cpp.C0.d
  arm64/gnu/optimized CX CascadeClassifierCore-cpp.o
  arm64/gnu/optimized CX HOGDescriptorCore-cpp.o
  arm64/gnu/optimized CX agast_score_mw-cpp.o
  arm64/gnu/optimized CX cgCommon-cpp.o
  arm64/gnu/optimized CX detectBRISKCore-cpp.o
  arm64/gnu/optimized CX detectFASTCore-cpp.o
  arm64/gnu/optimized CX detectKAZECore-cpp.o
  arm64/gnu/optimized CX detectMserCore-cpp.o
In file included from ../HOGDescriptorCore.cpp:15:0:
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/cgCommon.hpp: In instantiation of 'void copyToMatBGR_RowMaj(ImageDataType*, ImageDataType*, int, int, int) [with ImageDataType = unsigned char]':
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/cgCommon.hpp:270:41:   required from 'void cArrayToMat_RowMaj(const ImageDataType*, int, int, bool, cv::Mat&) [with ImageDataType = unsigned char]'
../HOGDescriptorCore.cpp:74:67:   required from here
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/cgCommon.hpp:93:103: warning: unused parameter 'channels' [-Wunused-parameter]
 void copyToMatBGR_RowMaj(ImageDataType *src, ImageDataType *dst, int numRowsInBlock, int numCols, int channels)// remove channels from here
In file included from ../detectBRISKCore.cpp:15:0:
../detectBRISKCore.cpp:97:60:   required from here
In file included from ../detectFASTCore.cpp:14:0:
../detectFASTCore.cpp:86:67:   required from here
../detectMserCore.cpp: In function 'void regionsToPointsArrayRM(std::vector<std::vector<cv::Point_<int> > >&, int32_T, int32_T*, int32_T*)':
../detectMserCore.cpp:61:66: warning: unused parameter 'numTotalPts' [-Wunused-parameter]
 void regionsToPointsArrayRM(vector< vector<Point> > &in, int32_T numTotalPts,
In file included from ../detectKAZECore.cpp:14:0:
../detectKAZECore.cpp:34:73:   required from here
In file included from ../detectMserCore.cpp:12:0:
../detectMserCore.cpp:162:67:   required from here
  arm64/gnu/optimized CX disparityBMCore-cpp.o
  arm64/gnu/optimized CX disparitySGBMCore-cpp.o
  arm64/gnu/optimized CX extractBRISKCore-cpp.o
  arm64/gnu/optimized CX extractFreakCore-cpp.o
  arm64/gnu/optimized CX extractKAZECore-cpp.o
  arm64/gnu/optimized CX extractSurfCore-cpp.o
  arm64/gnu/optimized CX face_detection_camera_main-cpp.o
  arm64/gnu/optimized CX face_detection_camera_main_emxutil-cpp.o
In file included from c:\users\stefan\appdata\roaming\mathworks\matlab-add-ons\toolboxes\nxp_vision_toolbox_for_s32v234\internals\src\include\nxpvt_cascadeobjectdetectorlbp.hpp:31:0,
                 from ../face_detection_camera_main.cpp:4:
../graphs/build-apu-nxp-sa-d/APU_CASCADE_OBJECT_DETECTION_LBP_4.hpp:5:97: fatal error: APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h: No such file or directory
 #include <APU_CASCADE_OBJECT_DETECTION_LBP_4_APU_LOAD.h> //APU load associated with this process
compilation terminated.
make[3]: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/helpers.mk:174: face_detection_camera_main-cpp.o] Error 1
make[3]: *** Waiting for unfinished jobs....
In file included from ../disparityBMCore.cpp:13:0:
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp: In function 'void copyClipAndCastBMRM(int16_T*, real32_T*, mwSize, mwSize, mwSize, mwSize, mwSize, int16_T, mwSize)':
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp:183:9: warning: unused parameter 'numInRows' [-Wunused-parameter]
  mwSize numInRows, int16_T invalidValue, mwSize borderWidth)
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp: In instantiation of 'void copyAndPadRM(T*, T*, mwSize, mwSize, mwSize, mwSize, mwSize) [with T = unsigned char; mwSize = long unsigned int]':
../disparityBMCore.cpp:96:79:   required from here
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp:44:9: warning: unused parameter 'numInRows' [-Wunused-parameter]
  mwSize numInRows)
In file included from ../disparitySGBMCore.cpp:13:0:
../disparitySGBMCore.cpp:103:79:   required from here
  mwSize numInRows)
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp: In instantiation of 'void copyAndClipRM(T*, T*, mwSize, mwSize, mwSize, mwSize, mwSize, T, mwSize) [with T = float; mwSize = long unsigned int]':
../disparitySGBMCore.cpp:139:37:   required from here
D:/MATLAB/R2018b/toolbox/vision/builtins/src/ocv/include/disparityBM.hpp:112:9: warning: unused parameter 'numInRows' [-Wunused-parameter]
  mwSize numInRows, T invalidValue, mwSize borderWidth)
In file included from ../extractBRISKCore.cpp:14:0:
../extractBRISKCore.cpp:147:60:   required from here
In file included from ../extractKAZECore.cpp:11:0:
../extractKAZECore.cpp:124:73:   required from here
make[3]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[2]: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/platforms/coordinator.mk:57: all] Error 2
make[2]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make[1]: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/sub.mk:74: allsub] Terminated
make[1]: Leaving directory '/c/Users/stefan/AppData/Roaming/MathWorks/MATLAB-Add-Ons/Toolboxes/NXP_Vision_Toolbox_for_S32V234/examples/apps/face_detection/codegen/exe/face_detection_camera_main/build-v234ce-gnu-linux-o'
make: *** [/d/NXP/VisionSDK_S32V2_RTM_1_2_0_HF1/s32v234_sdk/build/nbuild/platforms/coordinator.mk:57: allsub] Error 2
thank you very much!
paulvlase
Hi wweir0618@outlook.com‌,
I don't understand why it fails.
Could you attached the codegen folder as a zip archive?
When you write a message you have "Use advanced editor" option to attach files.
wweir0618
Hi, paulvlase
Here is the  zip archive, thanks!
