How to dual-player on I.MX8M board
coindu
Hi:all
          I want to know to play different video on different displays.
          Environmental description:
                       linux system
                       kernel version    4.9.88
         DCSS connect to HDMI, LCDIF connect to mipi and mipi bridge to lvds display.
when the system is up ,the kernel logo and psplash display on the HDMI screen and the weston desktop display on the  panel. Under the directory /dev can find fb0 and fb1 . no matter how to fill picture on fb1,the panel still display the weston desktop.   but use mouse and keypad can move and input keys on the panel .
        If I play a video, it will display on the HDMI screen. so i think the HDMI and panel work well  at least.
the Document i.MX_Graphics_User's_Guide.pdf  7.3.1.6.1  Playing different videos on different displays
       video-sink is not exist on the system.
         please give me the command to test it. Thanks.
joanxie
I got reply:
Two different videos on the same display is supported, but two different videos on two different displays is not supported for 8M.
venkatesh_selva
Hello Coin du,
Can you share your device tree changes? I'm also working on the same.
Venkatesh
venkatesh.selvaraju@pciltd.com.sg
coindu
I use tc358775IC convert MIPI-DSI to LVDS.
The attachment provides 3 examples signal DCSS to panel,signal LCDIF to panel and DCSS to hdmi, LCDIF to panel dual play.
