Use FRDM-KL25Z as a debug probe.
Question asked by jun yamada on Jan 15, 2019
Latest reply on Jan 16, 2019 by jun yamada
Thank you for your help.
It cut J11 as shown in the FRDM-KL25Z user's manual and connected to SWDCLK and SWDDIO of the MCU outside the board.
The external MCU is MKM14Z64ACHH5.
If you set the debugger to PE-micro from EWARM of IAR and write to flash
First, when the PEMICRO Connection Manager screen appears and press Connect, an error message appears.
Error 17926. Target Type MCU mismatch. Unexpected processor detected. Aborting debug sesion.
① Does OpenSDA of FRDM-KL25Z check the CPU, and an MCU different from the KL25Z in the board causes an error?
② Is there a way to avoid this error and erase / write the external MKM14Z64ACHH5?
Thanks for your instruction.
