USB -> I2S bridge on MKL26Z
Question asked by Jason Lambert on Jan 14, 2019
Latest reply on Jan 15, 2019 by Jason Lambert
Hi All,
Has anyone tried to port the USB OTG to I2S example for the LPC5411x device described in this app note to run on the MKL26Z? They are both M4 based devices and I bet the peripherals are pretty similar so the HAL should be similar.
I would like to make an application that is a simple USB device that has one I2S output that drives a DAC. The MKL26Z is the only device I have found that has one I2S channel hence the reason I selected that part.
Any help would be great thanks.
Jason
