#LS1046A RDB,#BOM LS1046A,#ventilation fan P/N,cooling fan P/N
Which exactly RDB revision is in question?
Please provide a clear photo of the on-the-case stickers.
The RDB P/N is LS1046ARDB-PB.
Pls, check it over the document where the picture shown.
Ths,
Please see the fan data sheet attached.
Hi Ufedor,
Thanks a lot for the information.
Is it the same cooling fan using in the board where LS1046A processor cooling fan and other 2 side ventilation fans are same one, as provided P/N?
The provided data sheet is for the chassis fans.
Thanks for the answer.
Can I have the information of the cooling fan P/N of the LS1046A in the top?
Pls, provided me the detail info and full P/N as well.
There is no such fan on the LS1046ARDB-PB:
