S32K144 cann't download program
Question asked by Tony Zhang on Jan 13, 2019
Latest reply on Jan 22, 2019 by Tony Zhang
      I'am working on S32K144(100*PIN), now I can't reprogram the flash while I can do it successfully earlier.
      I see it's always staying #cyclic reset that is indicated by TRACE32, after the board is powered on. And then when I run TRACE32script to download program, it will run to stay #erasing flash and never exit then. During this progress, I use flash.UNSECUREerase command.
      How should I do to download a program in this condition? Hopefully you will give me some instruction. Thank you!
DEV environment: Eclipse+IAR, TRACE32, Lauterbach debugger, S32K144
