What are the best debugger options for LS1046A Reference Board? What kind of emulators/probes are needed for JTAG Support?
shamanth_kudali
Wanted to know if the JTAG port on the board is the best debugging option and how to interface with this JTAG port?
Labels (2)
Pavel
The LS1046A JTAG/COP interface usually is used for debugging.
NXP offers CodeWarrior Networking Application for development code and debugging on the LS1046A boards:
https://www.nxp.com/products/processors-and-microcontrollers/additional-processors-and-mcus/digital-...
This CodeWarrior uses CodeWarrior TAP for code loading and debugging:
https://www.nxp.com/support/developer-resources/software-development-tools/codewarrior-development-t...
and QorIQ LS Processor Probe Tips for CodeWarrior TAP:
CodeWarrior TAP uses JTAG/COP connection to the LS1046a.
See also TRACE32 from Lauterbach:
https://www.lauterbach.com/frames.html?home.html
and debuggers on the following page:
https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus/qoriq-lay...
Pavel Chubakov
shamanth_kudali
Thanks for the response Pavel.
Had a few more questions.
Query 1: Will the combination of Code Warrior, TAP and QorIQ LS Processor Probe Tips be sufficient for the below debugging features?
  1. Tracing and obtaining a trace log of execution.
  2. Single Step Debugging
  3. Breakpoints – How many?
Query 2: Is there any other open source IDE available as an alternative for Code Warrior?
If no, what are the licensing options for Code Warrior?
Pavel
Pavel Chubakov
