In the routine jn-an-1219-zigbee-3-0-controller-and-switch, I changed the address parameter of the sending function eCLD_OnOffCommandSend() and sent the switch state to the coordinator by the diplomatic node. In case of a problem, the data was sent successfully, but no data was found in the coordinator log. why?
The coordinator sends the node, and the node log shows that it has been received.
SDK:JN-SW-4170 v1840
jn-an-1219-zigbee-3-0-controller-and-switch 1007
How did you modify the function? Also, what do you mean by the diplomatic node?
I'm going to use a switch as a node,How do I report the status of the switch to the gateway?Is this the function?eCLD_OnOffCommandSend()
There is not n implementation like what you are looking for in that specific AN, nonetheless, you can base it on the
JN-AN-1220 and check the app_reporting.c to adapt it to your need in the application note you are working.
Sorry for the inconveniences this might cause you
