GPIO Mode
GPIO Mode
walker_xiao
Hello
I am using the NXP FS32K144, I want to know if GPIO supports open-drain output mode, push-pull output mode.
dianabatrlova
The device does not support open drain on all the pins. Only pins that are configured for a protocol that requires open-drain (e.g;, LPI2C, LPUART single-wire) will work in open-drain mode.
So, the GPIO pins support push-pull output mode.
I hope it helps you.
Diana
walker_xiao
Thank you
