Hi All,
I have the CLRC663 development kit (OM26630FDK) and it can work with the example codes in MCUXpresso IDE.
But if I disconnect the LPC-Link or if I only do the flash programming without debug mode in MCUXpresso IDE,
then the CLRC663 looks not working.
It seems it only can run with debug mode. Is there any method to run without debug mode ?
Albert
What do you mean by not working? Do you have an error or something? which example you are using? Could you please provide more details ?
