ENC_ECB problem
ENC_ECB problem
a_yusof
i am quite new with NXP S32K144. I want to ask about the encryption using CSEC. I am using ENC_ECB and the encrypted text is the same as the plain text. Am i missing something? I have already referred to the example 3_Basic_Operations and ran the example code with ENC_CBC, i faced the same problem. The encrypted text is the same as plain text.
Thank you in advance.
Jazmi
dianabatrlova
Hello Jazmi,
At first, I need to ask you, did you follow the steps in the "4 Programming the CSEc Security Module" in the  AN5401?
https://www.nxp.com/webapp/Download?colCode=AN5401
There is an important description:
"4.1 PRGPART: Program Partition Command
To start using the CSEc command set, the user must configure the device into emulated-EEPROM mode."
Did you run the Program Partition Command?
I would like to recommend you the working example, but I cannot share it on the community.
Could you please create a ticket? How to submit a new question for NXP Support
Thank you.
Diana
a_yusof
Hello Diana,
thank you for the reply. I have configured it before for the partition using this:
flash_error = configure_part_CSEc();
I have created the ticket. Case 00195659
Thank you.
Jazmi
