I want to use fxth871x7, but I don't know which emulator to match.
wangjw
What are the suitable simulation software and simulator (writing program)? Does Win10 use environment support it?
TomasVaverka
As an IDE, you need CodeWarrior for MCUs (Eclipse IDE). There is now a fully free version that can be downloaded from CodeWarrior Downloads|NXP. Select the special edition which is free and not time-limited. It is code size limited,  but the limit is 64kB, which is enough for 16kB FXTH.
You might also find useful a setup guide for CodeWarrior (Installing and using CodeWarrior 10.x for TPMS applications).
For programming and debugging we recommend using the P&E Micro Universal Multilink.
I hope it helps. If I misunderstood your question or if you have further questions, please let me know.
Tomas
