If CSI doesn't use, is it possible to open NVCC_CSI pin?
Sugiyama
Hi Sugiyama
recommendations for unused module connections are given in
sect.3.2 Recommended Connections for Unused Analog Interfaces i.MX6ULL Datasheet
https://www.nxp.com/docs/en/data-sheet/IMX6ULLCEC.pdf
All other power supplies should be applied even its modules are not used
to avoid leakage from powered domains to unpowered.
So if CSI doesn't use, NVCC_CSI power should be applied.
Hi, Igor,
Thank you for answer.
I understood.
Sugiyama
