In chapter 10.1 startup, it said The PF4210 can be configured to start up from either the internal OTP configuration, or with a hard coded configuration built into the device. What is the difference between 1) hard coded configuration 2) internal OTP configuration 3) default configuration and 4) preprogrammed OTP configuration?
Solved! Go to Solution.
Hi M.C
Please note that hard coded configuration is same with default configuration .
preprogrammed OTP configuration is same with internal OTP configuration.
Hi M.C
