The program can not be loaded into the MCU
增强祝
The program can not be loaded into the MCU. However, it worked normally last days.
Carlos_Mendoza
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
增强祝
Thanks for your response.
The problem has been solved.The reason is that the wire connecting the PC and MCU is broken.
Best wishes!
