Req: ibis model for micro controller LPC4367JBD208E
manish_sharma2
HI,
In my new design i am interfacing LPC4367JBD208E microcontroler with SDRAM and Flash. I need ibis model for micro controller LPC4367JBD208E to check the routing and impedance matching (for 100Mhz communication rate).
Manish
manish_sharma2
HI Bernhard,
Problem still persist. I am able to import the file in hyperlyx version 8. But there the part is showing only INPUT. So i am not able to drive my signal.
Manish
bernhardfink
It is the same file for all flash based devices of LPC43xx, you can find it on this site (scroll down):
LPC4357JBD208|Arm Cortex-M4/M0|32-bit MCU|NXP
Bernhard.
manish_sharma2
Not able to import the file as suggested by you Mr. Bernhard.
bernhardfink
This is not much information.
So you downloaded the file from our website and in which tool do you try to import it?
Do you have any error messages from this tool?
Bernhard
manish_sharma2
HI,
I tried to import that file in hyperlynx tool for impedance matching. But not able to import the ibis model of the downloaded part.
bernhardfink
The file passes at least the standard syntax checks for an IBIS file v4.2.
Do you have any error message from the tool which could help to analyze what#s wrong with it?
Bernhard.
manish_sharma2
Screenshot of the error while importing the IBIS file.
Tool using is: hyperlynx V9.2
bernhardfink
Can you please give it a try after applying changes in the IBIS file.
- remove the 2 tabs
- replace empty line by a line starting with a  |
- insert a line starting with a  | between [Component] and [Manuafcturer]
Bernhard.
manish_sharma2
HI Bernhard,
modified the file as suggested.
still the problem persist.
Moreover, I am able to import the file in hyperlyx version 8. But there the part is showing only INPUT. So i am not able to drive my signal.
Till the time request you to please provide the Board file of the evaluation board of LPC (link is attached) for my reference
https://www.nxp.com/support/developer-resources/nxp-designs/hitex-lpc4350-evaluation-board:OM13031
Regards Manish
bernhardfink
Hi Manish,
try it with another modification:  add a space between [Command] and lpc18xxFBD208
The data for the Hitex Rev A4 board is attached.
Bernhard.
