Dear ZhangJennie,
I succeedded compile my project using your article as attached.
But is there any way to,
1. Automated download way( using command line interface), or
2. Download command line interface(Attached document includes compile process only)
Please help me with an urgent and important issue.
My project is PIL(Processor In the Loop) simulation based on simulink platform.
Thank you in advance.
Hyunuk
# codewarrior , commandlineinterface
Solved! Go to Solution.
Hi Hyunuk,
Professor Erich Styger ever wrote article about CodeWarrior Flash Programming from a DOS Shell.
CodeWarrior Flash Programming from a DOS Shell | MCU on Eclipse
Please check if this can help you.
Jun Zhang
Hi Hyunuk,
Jun Zhang
