Does the workshop model correspond to Model-Based Design Toolbox for S32K14x Automotive MCU 2018.R1
Link error such as config block appears.
If you do not seem to be compatible, could you add a corresponding model
Solved! Go to Solution.
I confirmed that there is a model of 2018R1 in workshop.
Thank you.
