newlib_nano under S32 DS
hanisamara
i am trying to create a c++ project under S32DS for KEA128 Controller with newLib_nano no IO. But when i build the project (empty, just main) the code size is about 47k? did i miss anything to set? i did the same with a C Project and the code size is less than 1k?
thanks in advance,
Hani
jiri_kral
can you please share your C++ project? I created new empty one for C++ with NewLib nano - and the code size is  less than 1kB:
Jiri
hanisamara
Hello Jiri,
thank you for your reply. I tried to update S32 DS and now it works correct and i have the same result as you.
Thanks for your support,
Hani
