Hi,Liqiang
We are developing 4 camera surroundview application, based on imx6d/OV10635/MAX96705/MAX9286 boards,
the patch we apply is L3.14.52_GA1.1.0_MAX9286_Surroundview_Patch_2016-07-26.zip.
But the image color is NOT right as following:
(see attach: color-error.png)
My environment as following:
图像可以显示,就是颜色不对。
Can you please help to tell what's the problem ?
pls follow the another simliar case you created, I will close this one.
