Is it possible to display fahrenheit values on a Rapid IoT temperature data glance on the dashboard?
Yes! On the connector from the Cloud Event to Cloud Storage - make the VALUE value*9/5+32
You can also limit the number of digits with value.toFixed(X) where X is 1, 2, 3 whatever you want. See the Weather Station Example app for more options.
Are you working with the Rapid IoT Studio or MCUXpresso?
Estephania
Hello Estephania,
I am using https://rapid-iot-studio.nxp.com/ <https://rapid-iot-studio.nxp.com/>
Bryant
You can use the example available in the studio called Embedded Mathematical Operation Demo. Have you tried it? do you have issues while using it ? If you do, just let me know.
