LF RF communication FXTH870xD - MRB-KW019030JA
dskim
I'm using MRB-KW019030JA with (MKW01_IAR7v4_Project_TPMS_Rev0.6) project, also I have FXTH870xD sensor module But I recently realized that MRB-KW019030, MRB-KW019032 has different crystal.
MRB-KW019030 has 30Mhz and the other has 32Mhz.
unfortunately the project recommand KW019032 and I have only KW019030 I have no idea how to modify the source code I just found this
//#define USE_32MHZ_CLKO //Enable this macro when using a 32MHZ crystal fed to the MKW01Z128CHN
#define USE_30MHZ_CLKO //Enable this macro when using a 30MHz crystal fed to the MKW01Z128CHN
in derivative.h so I fix it to 30Mhz
could somebody tell me how to fix this code more to fit on my MRB-KW019030?
dskim
Hi Tomnas,
The project name is TPMS MKW01 Reference Project LF RF Communication KDS3 not MKW01_IAR7v4_Project_TPMS_Rev0.6
it was my mistake
you can download project here Search Results: TPMS MKW01 Reference Project LF RF Communication KDS3
Thankyou
TomasVaverka
Hi  Daeseon,
Please check the attached project and let me know if it helps you.
Tomas
