Kinetis SDK 2.0.I2C library.
Question asked by jun yamada on Dec 26, 2018
Latest reply on Dec 27, 2018 by jun yamada
Please kindly advise.
I am using the I2C library of Kinetis SDK 2.0.
One byte of data was transmitted from the host to the General Call Address by setting the slave to General Call Address Enable.
Incoming callbacks are called, but the data is not as expected. Probably, I think that I did not specify the read buffer. Which API do you do?
