How can I use inter-Pan in AN-1184
374216459
Hi all,
      I need to use Inter-Pan broadcast to send some private data, at first,the inter-PAN feature has been enabled via the ZPS Configuration Editor:
And then,I compiler project reported some error as below:
 what's more,I found it can't receive inter-pan unicast (64bit-address) message from another node
Thank you!
mario_castaneda
Hi Zhang,
You can refer to bulb application note which supports touchlink as it uses inter-pan JN-AN-1218
and also the stack user guide.
And if required you can refer to touchlink in bulb application note for understanding how inter-pan messages are sent and received
Mario
