How to make an NPF file out of an existing LDF file in codeworrior10? Why is the Network definition option LDF file and Node name blank? I need somebody help .
HI Jackie,
I ever tested NPF file exporting feature, If I well installed the ncf plugin, there is no problem.
- What's your CW version?
- What's your LIN stack version?
- Can you please send me the steps of reproducing this issue?
Jennie Zhang
The problem has been solved.thinks for your help.
Hi Jackie,
That's good. You are welcome.
Jun Zhang
