I am running opengl test program tutorial6_es20 based on bsp19.0 in s32v234evb, there is a problem
Question asked by weiyi weiyi on Dec 20, 2018
Latest reply on Dec 26, 2018 by Mike Doidge
hi
I am running the tutorial6_es20 based on bsp19.0 in s32v234evb. I have the following information, I am doing this?
root@s32v234evb:/opt/viv_samples/vdk# ./tutorial6_es20
[ 1280.300134] fsl_dcu 40028000.dcu: DCU: unable to allocate memory for <fb0> surface.
[ 1280.300138] detected fb_set_par error, error code: -12
[ 1280.312574] fsl_dcu 40028000.dcu: DCU: unable to allocate memory for <fb0> surface.
[ 1280.312577] detected fb_set_par error, error code: -12
[ 1] NOTICE: Flush cache for USER_POOL memory!
500 frames in 8372 ticks -> 59.723 fps
Thank you !
