hi, all
I flash iMX8QXP-CM4 image in an error address using JLINK-flash.exe.when i connect JLINK using JTAG again,it cann't connect.
Device "MIMX8QX6_M4" selected.
Connecting to target via JTAG
J-Link script: iMX8QX Cortex-M4 core0 J-Link script
TotalIRLen = 4, IRPrint = 0x01
JTAG chain detection found 1 devices:
#0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP
AP map detection skipped. User manually configured AP map.
AP[0]: AHB-AP (IDR: Not set)
AP[1]: AHB-AP (IDR: Not set)
AP[2]: AHB-AP (IDR: Not set)
AP[3]: AHB-AP (IDR: Not set)
AP[4]: APB-AP (IDR: Not set)
AP[2]: Skipped. Could not read AHB ROM register
AP[2]: Skipped. No ROM table (AHB-AP ROM base: 0x00000000)
****** Error: Bad JTAG communication: Write to IR: Expected 0x1, got 0x0 (TAP Command : 10) @ Off 0x5.
Could not find core in Coresight setup
Cannot connect to target.
Hi meng
recommended debugging procedure is described in
sect.5.1.3 Run an example application attached document
Getting Started with MCUXpresso SDK for i.MX 8QuadXPlus.pdf.
Issues with J-Link can be posted on segger forum
J-Link/Flasher related - SEGGER - Forum
hi, igorpadykov
Thank you for your reply,I've solved my problem by reloading the SD card image(SCFW and ahab-container.img).
