how to support usb gadget serial function correctly for imx6q
Question asked by hui wang on Dec 19, 2018
Latest reply on Dec 27, 2018 by jimmychan
system:android 5.1
platform:imx6q
now I do such operations below to add usb acm function:
1.add some code in init.freescale.usb.rc
   on property:sys.usb.config=acm,adb
   write /sys/class/android_usb/android0/enable 0
   write /sys/class/android_usb/android0/idVendor 18d1
   write /sys/class/android_usb/android0/idProduct 4e45
   write /sys/class/android_usb/android0/f_acm/instances 1
   write /sys/class/android_usb/android0/functions ${sys.usb.config}
   write /sys/class/android_usb/android0/enable 1
   start adbd
   setprop sys.usb.state ${sys.usb.config}
2.adb shell to set the usb property
   #setprop persist.sys.usb.config acm,adb    the default property is mtp,adb
3.install the gadget driver on my windows computer, it can identify the serial of COM24, and I can also communicate using this COM
But now question is when i want to change the usb property back
    #setprop persist.sys.usb.config mtp,adb
the android system will reboot at once, and the property is also acm,adb
what wrong with it and how can i config correctly to support usb gadget serial (acm) function?
Thanks a lot !
