FTFx_ERR_ACCERR by calling FlashInit (fsl_flash_driver)
Question asked by Paul Klarhöfer on Dec 20, 2018
Latest reply on Jan 3, 2019 by Diana Batrlova
I'm using a S32K144HAMLL processor.
I got a bootloader example project and have the following problem:
The call of the flash init function results in an FTFx_ERR_ACCERR error.
The error occurs in the following line:
ret = pFlashCommandSequence(pSSDConfig);
Does someone has a clue what might be wrong?
I attached a screenshot, where you can also see the values of the pSSDConfig variable.
In the specific line, where the error occurs, I don't find the function or macro for that, so I don't understand what is actually done in that line.
I hope you can help, I'm a little bit desperate figure this out. If you need more informations, let me know. I will provide them.
With best regards
Paul
