T2081 board
Question asked by Monali Haware on Dec 19, 2018
Latest reply on Dec 23, 2018 by alexander.yakovlev
i have custom board with T2081. It was getting connected using HARD CODED RCW (ddr_clk=sys_clk=66.67MHz). Now it shows "failed to configure JTAG chain".
JTAG log is as follows: What might be the problem?
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       ccs_open; ccs_error = 10
       Error message: Connection refused
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       ccs_open; ccs_error = 0
ccs_get_connection_count
       serverh = 0
       count = 1
       ccs_get_connection_count; ccs_error = 0
ccs_available_connections
       serverh = 0
       count = 0
       ccs_available_connections; ccs_error = 0
       serverh = 0
       count = 0
ccs_config_cc
       serverh = 0
       config_string = powertap:192.168.1.2
       ccs_config_cc; ccs_error = 0
       serverh = 0
       count = 1
ccs_set_timeout
       serverh = 0
       timeout = 15
       ccs_set_timeout; ccs_error = 0
ccs_cc_status
       serverh = 0
       cc = 0
       ccs_cc_status; ccs_error = 0
ccs_cc_version
       serverh = 0
       cc = 0
       version.major = 1
       version.minor = 0
       ccs_cc_version; ccs_error = 0
ccs_set_timeout
       serverh = 0
       timeout = 15
       serverh = 0
       count = 1
ccs_config_server
       serverh = 0
       cc = 0
       server_config = 0
       value = 10000
       ccs_config_server; ccs_error = 0
ccs_config_chain
       serverh = 0
       cc = 0
       device_list: (size = 1)
              device[0]:: core_type=test core(20)
       ccs_config_chain; ccs_error = 0
ccs_jtag_lock
       serverh = 0
       cc = 0
       ccs_jtag_lock; ccs_error = 0
JTAG Diagnostics
Starting Power at Probe test ...
Test result: PASSED
Starting IR Scan test ...
Test result: PASSED
Starting Bypass Scan test ...
Test result: PASSED
Starting Arbitrary TAP State Move test ...
Test result: PASSED
Detected JTAG IDCODEs: OK
Device 0 IDCODE: 0x118E601D
ccs_jtag_unlock
       serverh = 0
       cc = 0
       ccs_jtag_unlock; ccs_error = 0
ccs_config_chain
       serverh = 0
       cc = 0
              device[0]:: core_type=T2080(242)
ccs_config_template
       coreh = [serverh:0;cc_index:0;chain_pos:0]
       config_reg = 2
       config_data = 1
       ccs_config_template; ccs_error = 0
ccs_write_register
       index = 210001
       count = 1
       size = 4
       value: (size = 4)
               120C0017
       ccs_write_register; ccs_error = 0; duration=1 ms
ccs_write_register
       index = 210002
       count = 1
       size = 4
       value: (size = 4)
               15000000
ccs_write_register
       index = 210003
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210004
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210005
       count = 1
       size = 4
       value: (size = 4)
               6B000002
ccs_write_register
       index = 210006
       count = 1
       size = 4
       value: (size = 4)
               00008000
ccs_write_register
       index = 210007
       count = 1
       size = 4
       value: (size = 4)
               F9027000
ccs_write_register
       index = 210008
       count = 1
       size = 4
       value: (size = 4)
               01000000
ccs_write_register
       index = 210009
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210010
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210011
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210012
       count = 1
       size = 4
       value: (size = 4)
               000307FC
ccs_write_register
       index = 210013
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210014
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210015
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210016
       count = 1
       size = 4
       value: (size = 4)
               00000004
ccs_reset_to_debug
       serverh = 0
       cc = 0
       ccs_reset_to_debug; ccs_error = 39
       Error message: T2080: Core not responding
ccs_get_subcore_error
       serverh = 0
       cc = 0
       error = 5
       chain_pos = 0
       ccs_get_subcore_error; ccs_error = 0; duration=1 ms
ccs_kill_server
       serverh = 0
       ccs_kill_server; ccs_error = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       serverh = 0
       count = 1
       serverh = 0
       count = 0
       serverh = 0
       count = 0
ccs_config_cc
       serverh = 0
       serverh = 0
       count = 1
ccs_set_timeout
       serverh = 0
       timeout = 15
ccs_cc_status
       serverh = 0
       cc = 0
ccs_cc_version
       serverh = 0
       cc = 0
       version.major = 1
       version.minor = 0
ccs_set_timeout
       serverh = 0
       timeout = 15
       serverh = 0
       count = 1
ccs_config_server
       serverh = 0
       cc = 0
       server_config = 0
       value = 10000
ccs_config_chain
       serverh = 0
       cc = 0
ccs_jtag_lock
       serverh = 0
       cc = 0
JTAG Diagnostics
Test result: PASSED
Test result: PASSED
Test result: PASSED
Test result: PASSED
ccs_jtag_unlock
       serverh = 0
       cc = 0
ccs_config_chain
       serverh = 0
       cc = 0
ccs_config_template
       config_reg = 2
       config_data = 1
ccs_write_register
       index = 210001
       count = 1
       size = 4
       value: (size = 4)
               120C0017
       ccs_write_register; ccs_error = 0; duration=0 ms
ccs_write_register
       index = 210002
       count = 1
       size = 4
       value: (size = 4)
               15000000
ccs_write_register
       index = 210003
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210004
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210005
       count = 1
       size = 4
       value: (size = 4)
               6B000002
ccs_write_register
       index = 210006
       count = 1
       size = 4
       value: (size = 4)
               00008000
ccs_write_register
       index = 210007
       count = 1
       size = 4
       value: (size = 4)
               F9027000
ccs_write_register
       index = 210008
       count = 1
       size = 4
       value: (size = 4)
               01000000
ccs_write_register
       index = 210009
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210010
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210011
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210012
       count = 1
       size = 4
       value: (size = 4)
               000307FC
ccs_write_register
       index = 210013
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210014
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210015
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210016
       count = 1
       size = 4
       value: (size = 4)
               00000004
ccs_reset_to_debug
       serverh = 0
       cc = 0
       serverh = 0
       cc = 0
       error = 5
       chain_pos = 0
ccs_kill_server
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       serverh = 0
       count = 1
       serverh = 0
       count = 0
       serverh = 0
       count = 0
ccs_config_cc
       serverh = 0
       serverh = 0
       count = 1
ccs_set_timeout
       serverh = 0
       timeout = 15
ccs_cc_status
       serverh = 0
       cc = 0
ccs_cc_version
       serverh = 0
       cc = 0
       version.major = 1
       version.minor = 0
ccs_set_timeout
       serverh = 0
       timeout = 15
       serverh = 0
       count = 1
ccs_config_server
       serverh = 0
       cc = 0
       server_config = 0
       value = 10000
ccs_config_chain
       serverh = 0
       cc = 0
ccs_jtag_lock
       serverh = 0
       cc = 0
JTAG Diagnostics
Test result: PASSED
Test result: PASSED
Test result: PASSED
Test result: PASSED
ccs_jtag_unlock
       serverh = 0
       cc = 0
ccs_config_chain
       serverh = 0
       cc = 0
ccs_config_template
       config_reg = 2
       config_data = 1
ccs_write_register
       index = 210001
       count = 1
       size = 4
       value: (size = 4)
               120C0017
ccs_write_register
       index = 210002
       count = 1
       size = 4
       value: (size = 4)
               15000000
ccs_write_register
       index = 210003
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210004
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210005
       count = 1
       size = 4
       value: (size = 4)
               6B000002
ccs_write_register
       index = 210006
       count = 1
       size = 4
       value: (size = 4)
               00008000
ccs_write_register
       index = 210007
       count = 1
       size = 4
       value: (size = 4)
               F9027000
ccs_write_register
       index = 210008
       count = 1
       size = 4
       value: (size = 4)
               01000000
ccs_write_register
       index = 210009
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210010
       count = 1
       size = 4
       value: (size = 4)
               00000000
       ccs_write_register; ccs_error = 0; duration=2 ms
ccs_write_register
       index = 210011
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210012
       count = 1
       size = 4
       value: (size = 4)
               000307FC
ccs_write_register
       index = 210013
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210014
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210015
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210016
       count = 1
       size = 4
       value: (size = 4)
               00000004
ccs_reset_to_debug
       serverh = 0
       cc = 0
