I am trying to get some insight for Ethernet communication.
I am using Nxp S32k148 eval board with TJA110x Transceiver for that.
Need sample code to Communicate between two PHY controller via Ethernet.
Some body kindly provide me the code, if you already have.
Thank you very much in Advance
Bikash
@danielmartynek Hi Daniel,
I am working on the same example. However, the example file which I have of phy_tja1101_s32k148 (SDK v2.9.2) has few header files missing
(Dont know how and why) could you please. Mail me complete folder for this example on akshayu10i@gmail.com Would really appreciate you help as I have spent a lot of time searching for the files.
Hi Bikash,
There is phy_tja1101_s32k148 (SDK v2.9.2) example in the S32 Design Studio.
