HCS12 PROGRAMMER failed to read s-File
wojinandawei
I'M using USBDM 4.12.1.240.
My MCU is MC9SG128.
I want to use HCS12 programmer to programme my mcu, but when load hex file, it tells me "Failed to read S-File".
But when I load S19 files in "USBDM 4.12.1.240\DeviceData\HCS12", it read well.
So,why this happen, what should I do to get through thi situation.
Please help.
Thanks a lot.
wojinandawei
I have solved this issue .
The reason that programmer can't read my *.s19 file is this:
   the s19 file must be placed in the direction(C:\Program Files (x86)\pgo\USBDM 4.12.1.240\DeviceData\HCS12).
After place the file well, the the programmer read it correctly.
ZhangJennie
Your issue related with USBDM, please move your question here
https://community.nxp.com/community/bdm
Jennie Zhang
