Dear Tech support,
I tried to upgrade the debugging firmware from OPENSDA CDC to Jlink Open SDA .
I hold down SW2 and plug in the USB cable on J10/SDA port.
The PC see the the bootloader.
I tried all 3 different versions generic and one specific to KL26Z.
The files seems to upload just fine, but after unplugging and re-plugging the usb cable the PC/Teraterm/Device manager cannot find the Jlink debugger.
The debugger light does not blink either.
I need to change from OpenSDA-CDC to Jlink because MCUXpresso won't recognize OpenSDA-CDC.
hy
I tried to upgrade the OPenSDA firmware with
Are you using Windows 10? Then you have to stop the storage service first, see Recovering OpenSDA Boards with Windows 10 | MCU on Eclipse
I hope this helps,
Erich
