I found a little mistake in the demo Applications. In the file accelerometer.c starting from line 486, the original code is: switch(sensitivity) { case Range15g: PTCD_PTCD4 = 0; PTCD_PTCD5 = 0; break; case Range2g: PTCD_PTCD4 = 0; PTCD_PTCD5 = 1; break; case Range4g: PTCD_PTCD4 = 1; PTCD_PTCD5 = 0; break; case Range6g: PTCD_PTCD4 = 1; PTCD_PTCD5 = 1; break; default: PTCD_PTCD4 = 0; PTCD_PTCD5 = 0; break; } The problem is that Range2g and Range4g are misplaced. So the correct code would be switch(sensitivity) { case Range15g: PTCD_PTCD4 = 0; PTCD_PTCD5 = 0; break; case Range4g: PTCD_PTCD4 = 0; PTCD_PTCD5 = 1; break; case Range2g: PTCD_PTCD4 = 1; PTCD_PTCD5 = 0; break; case Range6g: PTCD_PTCD4 = 1; PTCD_PTCD5 = 1; break; default: PTCD_PTCD4 = 0; PTCD_PTCD5 = 0; break; } Happy coding!
Message Edited by Andrei Boeru on 2008-12-2701:00 AM
