JPEG encode/decode using Coda960 driver?
Question asked by JONATHAN OLSON on Dec 11, 2018
Latest reply on Dec 17, 2018 by JONATHAN OLSON
The CODA driver in the latest mainline kernel supports JPEG encoding/decoding for coda7 (imx5x) platforms, but does not support JPEG for coda960 (imx6) platforms.
The coda_regs.h header file does not even define the coda960 MJPEG registers starting at 0x3000.  Is there any support planned for the coda960 JPEG unit in the coda driver?  It appears that supporting JPEG on the imx6 should a straightforward port of code in the imx-vpu library.
