Is the Local Memory Size Limitation of 1kB only for OpenCL Embedded Profile?
vinay_surendran
Section "5.3.5 Minimizing use of 1 KB local memory" of the “i.MX_Graphics_User's_Guide.pdf” document specifies that the local memory available is only 1kB.
Is this the case only for OpenCL Embedded Profile? Or does it also apply for OpenCL Full Profile?
I am using the GC7000Lite GPU on the iMX8M Quad EVK.
Do I have any such limits? What is the local memory available for use on the GC7000Lite GPU?
Thanks and regards
Vinay
