TDA8029 I2C Communication Problem
mfyasar111
Hello ,
We want to design a product using TDA8029.
We have no problem while we try UART Communication with the IC but we can't get any acknowledge when we try to use I2C protocol.
We tried all of the possible scenarios which is written in the datasheet.I also checked the mask number of IC.
I attached a scope view of SDA and SCL lines.
Do you have any advices for us ?
Thank you.
mfyasar111
CH2 is SDA , CH3 is SCL.
Kan_Li
Per your attached pic, would you please specify which line is for SCL and which line is for SDA?Thanks for your patience!
Kan
