S12ZVL - C code for CAN communication
andrearicca
I am developing a project that uses the microcontroller S912ZVLA12F0MLF. The application requires a CAN bus communication. Someone of you can tell me where I can find the C codes of CAN communication?
Thank you
Tags (4)
dianabatrlova
Hi Andrea,
The S12ZVL MCUs contain MSCAN module, but CAN physical layer is not available on this device. So, you have to use external CAN transceiver.
CAN Transceiver and Controllers|NXP
You can take a look at AN4975 - Using MSCAN on the MagniV Family
https://www.nxp.com/files-static/microcontrollers/doc/app_note/AN4975.pdf
SW:
http://www.nxp.com/files/microcontrollers/doc/app_note/AN4975SW.zip
I hope it helps you.
Diana
