I am writing an initialization routine for the MK10FX512VLQ12 MCU on a board we designed. In the "K10 Sub-Family Reference Manual with Addendum":
- https://www.nxp.com/docs/en/reference-manual/K10P144M120SF3RM.pdf
page 260, there is a table showing 6 ports, A through F. Furthermore when I generate a new project with KDS 3.2.0, it creates a header called \Includes\MK10F12.h which defines base addresses for 6 ports (lines 4461-4487).
However on pp. 246-247 of the same reference manual we see the pinouts of the LQFP and MAPBGA packages and there are only 5 I/O ports (No trace of port F). I can find no sign of it anywhere else in the reference manual.
I am a little concerned that I can configure and drive a port that doesn't exist. Is there a good reason for this?
Thanks, Robin! Will do.
Hi Gary Lynch,
Sorry for the inconvenience!
The part number listed in K10P144M120SF3RM don't have PORTF, please don't use this port in software.
Robin
