I was wondering what would be the default GPIO direction and value on imx6ul platform for the pins that are not configured specifically in the bootloader or by kernel in device tree?
I could not find in the imx6ul manual.
Mihaita
Solved! Go to Solution.
Hello Mihaita,
You can see the Out of Reset Condition on Tables 91 and 94 (depending on the package) of the i.MX6UL Datasheet and in Table 96 of the same document.
Hello Mihaita,
Thank you
Mihaita
