the question about the registers of flash controller
langweihua1643
Hello
Related to Flash memory , I found a conflict(maybe) need to support
In S32K14x Seriex Cookbook.pdf ,I found description as below:
It means ---> Value 1 means Enable , Value 0 means Disable;
But in S32K144_RM.pdf ,I found that
the conflict is :Value 0 means enable, Value 1 means disable
So I am confused about this ,which is correct ? or if my undersood is wrong?
Thank you.
best regards
danielmartynek
The current reference manual rev.9 is correct.
Value 0 means enable, Value 1 means disable.
And the default out-of-reset configuration of OCM1 is 0b00 that means enabled.
It was the other way round on the first S32K144 maskset 0N77P.
Thank you for pointing this out.
langweihua1643
Hey,
Thank you for your reply very much!
langweihua1643
(the attached picture may be upload failed)the register of my question is MSCM->OCMDR0 and MSCM->OCMDR1
