HI:
I use S12ZVC, I don't want bootloader and app use the same Interrupt Vector table,so i Relocating app interrupt vector table at other address:0xFF9000-0xFF92EF.
1.I modify the PRM file,Reallocation of address:
APP: 0xFE0000-0xFF8FFF;
APP interrupt mapping: 0xff9000-0xff92ef;
Boot: 0xff9400-0xffddff;
Boot interrupt mapping :Default interrupt vector address (memory end);
2.Relocating interrupt vector address:
3.Relocating Reset Vector address:
4.Set IVBR REG:0xFF90:
5.Modify APP's RPM :
6.Debug issue problem:
debug by step,the program run at MainLoop() leave,can not run correctly....
Is there any problem with the configuration?
I have noticed one thing, you set IVBR = 0xFF9000.
And reset vector at 0xFF8FF8.
It should be 0xFF91FC. Can you please try it?
