How to rebuild the wpa_supplicant with p2p enabled for wifi direct on i.mx8 prebuild linux image
abhishek_ps3
i am trying to enable the wifi direct in the i.mx8 running linux and in the pre-built wpa_supplicant the CONFIG_P2P is not enabled. so how to enable it without compiling the whole linux kernal image.
Labels (2)
Bio_TICFSL
Hi Abhishek,
You have to enable CONFIG_P2P and the you have compile the whole image, you can´t use it without compiled it.
abhishek_ps3
is it not possible to cross compile only wpa_supplicant through some cross compiling toolchain and add to the existing image?  and if there is a way can you brief about that.
