Yocto Application Development Using Eclipse IDE
Question asked by Erik Raynolds on Dec 6, 2018
Latest reply on Dec 8, 2018 by Erik Raynolds
I am using Eclipse IDE with ADT to develop the applications under Yocto SDK.
I have working "Hello World" project out of "Yocto Project SDK Autotools Project" templates and it runs with no problem.
But when I created "Hello World" using "Yocto Project SDK Cmake Project" templates
the project is not build
Build of project failed with the following error:
CMake Error: Could not find CMAKE_ROOT !!!
CMake has most likely not been installed correctly.
Modules directory not found in
/opt/fsl-imx-xwayland/sysroots/x86_64-pokysdk-linux/usr/share/cmake-3.5
CMake Error: Error executing cmake::LoadCache(). Aborting.
Under Yocto SDK installed in
/opt/fsl-imx-xwayland/4.9.51-mx8-beta/sysroots
there is cmake-3.6 which instead config points to cmake-3.5 ...
I have cmake included in my Yocto SDK build, what is the correct configuration of ADT Eclipse plugin?
