GStreamer - ValueError: Namespace GstRtspServer not available
imx_learner
I am trying to use gst-rtsp-server in my python application. for this I included the following :
      import gi
     gi.require_version('GstRtspServer','1.0')
     from gi.repository import GstRtspServer
However, I get the following error:
  File "/usr/lib/python3/dist-packages/gi/__init__.py", line 130, in require_version
    raise ValueError('Namespace %s not available' % namespace)
1. Later I tried installing rtsp-server from source from the following repo
:  https://gitlab.freedesktop.org/gstreamer/gst-rtsp-server.git
2. Compiling this gave me an error saying 'Gst-Rtsp.gir' files are missing
from '/usr/share/gir-1.0'. To resolve this I copied the required '*.gir'  files to  '/usr/share/gir-1.0' from repo :
https://github.com/sdroege/gstreamer-rs/blob/master/gir-files/GstRtsp-1.0.gir
3. make and make install was success.
4. However, when importing this GstRtspServer in my application, I still have the issue :
5. I have seen a number of posts on this issue, and also tried different solutions suggested, however this still is not resolved.
I am using Gstreamer 1.14.1
Does anyone have any pointers towards this issue ?
Tags (2)
joanxie
what bsp version do you use? you can refer to the i.mx linux user guide, chapter 7.3.14 RTSP streaming server
imx_learner
Also, I am not using Yocto environment, but directly downloading the source and using make & make install. Could you provide me pointers as to where I am going wrong.
imx_learner
How do I check the BSP version? I am using the Debian Stretch provided by Boundary Devices : Debian Stretch 9.2 for i.MX6/7 boards - October 2017 (kernel 4.1.15/4.9.x) - Boundary Devices
