Where to find source files for IMXRT1050-EVKB QSPI flash algorithm?
michaelsmith
I need to modify the QSPI flash algorithm to match a device that is different from what is shipped with the evaluation board.  The NXP pack for ARM MDK only provided the compiled .flm file.  Where can I find the source package that I can use to generate a custom flash algorithm file?
jeremyzhou
Hi Michael Smith,
We don't have the source file your request for, I think it will be contained in next version of Keil.
In my opinion, MCUXprsso IDE provides an easy way to modify or customize the memory layout, you can learn how to do it by referring to the attachment and please give a try.
TIC
