Vybrid initialization sequence
eishishibusawa
Dear Sir
I would like to ask about the initialization sequence of Vybrid.
Customer is executing with the following steps.
1.Clock initializaion;
2.UART initialization;
3.LPDDR iomux initialization;
4.LPDDR initialization (LPDDR controller and RAM).
Q1.
Is there a problem with the above order?
Eishi SHIBUSAWA
eishishibusawa
Dear NXP support member
Please reply this question.
Eishi SHIBUSAWA
Yuri
   Your initialization sequence is correct, but all initialization codes
should be located in and executed from  internal memory OCRAM.
Because of ECC  the entire OCRAM memory should be first
written during system startup.
Yuri
