s32v234sbc minipcie not work
无为无
Hi:
   I used the s32v234sbc development board to connect a pcie to usb module of renesas (uPD720202). This module has spi communication firmware attached externally, so there is no need to burn the firmware again.This module has been working normally on imx6q. Comparing the two .config files no error, Attachments come with the.config configuration in the kernel.
