lin_master_s32k148 Issue
Question asked by he wei on Nov 28, 2018
Latest reply on Jan 3, 2019 by he wei
Hello NXP,
I new a LIN_master project from your Example. But I can't build successfully.
The compiler log is the following. What can I do? Thanks!
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:197:5: error: unknown type name 'l_signal_handle'
     l_signal_handle         response_error;             /*!< Signal used to update response error */
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:201:11: error: unknown type name 'l_signal_handle'
     const l_signal_handle   *fault_state_signal_ptr;    /*!< List of fault state signal */
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:243:11: error: unknown type name 'l_frame_handle'
     const l_frame_handle * associated_uncond_frame_ptr; /*!< Associated unconditional frame ID */
In file included from D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:27:0,
                 from ../Generated_Code/Cpu.h:63,
                 from ../Generated_Code/Cpu.c:53:
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:290:5: error: unknown type name 'l_frame_handle'
     l_frame_handle      frm_id;         /*!< Frame ID, in case of unconditional or event triggered frame. For sporadic frame the value will be 0 (zero) */
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:370:57: error: unknown type name 'l_ifc_handle'
 extern lin_tl_callback_return_t lin_tl_callback_handler(l_ifc_handle iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:527:5: error: unknown type name 'l_ifc_slave_handle'
     l_ifc_slave_handle          slave_ifc_handle;          /*!< Interface handler of slave node */
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:528:5: error: unknown type name 'l_ifc_master_handle'
     l_ifc_master_handle         master_ifc_handle;         /*!< Interface handler of master node */
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:586:35: error: unknown type name 'l_ifc_handle'
 extern l_u8 ld_read_by_id_callout(l_ifc_handle iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:598:69: error: 'LIN_NUM_OF_MASTER_IFCS' undeclared here (not in a function)
 extern lin_master_data_t                    g_lin_master_data_array[LIN_NUM_OF_MASTER_IFCS];
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:601:71: error: 'LIN_NUM_OF_IFCS' undeclared here (not in a function)
 extern lin_tl_descriptor_t                  g_lin_tl_descriptor_array[LIN_NUM_OF_IFCS];
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:604:69: error: 'LIN_FRAME_BUF_SIZE' undeclared here (not in a function)
 extern l_u8                                 g_lin_frame_data_buffer[LIN_FRAME_BUF_SIZE];
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:605:67: error: 'LIN_FLAG_BUF_SIZE' undeclared here (not in a function)
 extern l_u8                                 g_lin_flag_handle_tbl[LIN_FLAG_BUF_SIZE];
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:606:73: error: 'LIN_NUM_OF_FRMS' undeclared here (not in a function)
 extern l_bool                               g_lin_frame_flag_handle_tbl[LIN_NUM_OF_FRMS];
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:608:14: error: unknown type name 'l_ifc_handle'
 extern const l_ifc_handle                   g_lin_hardware_ifc[HARDWARE_INSTANCE_COUNT];
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:608:64: error: 'HARDWARE_INSTANCE_COUNT' undeclared here (not in a function)
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:678:43: error: unknown type name 'l_ifc_handle'
 extern void lin_pid_resp_callback_handler(l_ifc_handle iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:699:21: error: unknown type name 'l_ifc_handle'
 l_bool lin_lld_init(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:709:21: error: unknown type name 'l_ifc_handle'
 void lin_lld_deinit(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:718:25: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_int_enable(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:727:26: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_int_disable(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:735:36: error: unknown type name 'l_ifc_handle'
 lin_node_state_t lin_lld_get_state(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:747:24: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_tx_header(l_ifc_handle iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:757:25: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_tx_wake_up(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:766:30: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_ignore_response(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:775:33: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_set_low_power_mode(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:788:27: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_set_response(l_ifc_handle iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:803:26: error: unknown type name 'l_ifc_handle'
 l_u8 lin_lld_rx_response(l_ifc_handle iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin.h:821:30: error: unknown type name 'l_ifc_handle'
 void lin_lld_timeout_service(l_ifc_handle iii);
In file included from ../Generated_Code/Cpu.h:63:0,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:77:17: error: unknown type name 'l_ifc_handle'
 l_u8 l_sch_tick(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:90:16: error: unknown type name 'l_ifc_handle'
 void l_sch_set(l_ifc_handle iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:91:16: error: unknown type name 'l_schedule_handle'
                l_schedule_handle schedule_iii,
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:114:19: error: unknown type name 'l_ifc_handle'
 l_bool l_ifc_init(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:131:23: error: unknown type name 'l_ifc_handle'
 void l_ifc_goto_sleep(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:141:20: error: unknown type name 'l_ifc_handle'
 void l_ifc_wake_up(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:149:25: error: unknown type name 'l_ifc_handle'
 l_u16 l_ifc_read_status(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:163:25: error: unknown type name 'l_ifc_handle'
 l_u16 l_sys_irq_disable(l_ifc_handle iii);
D:/program files/NXP/S32DS_ARM_v2018.R1/S32DS/S32SDK_S32K1xx_BETA_2.9.0/middleware/lin/include/lin_common_api.h:171:24: error: unknown type name 'l_ifc_handle'
 void l_sys_irq_restore(l_ifc_handle iii);
                 from ../Generated_Code/clockMan1.h:51,
                 from ../Generated_Code/clockMan1.c:39:
Executing target #4 ../Generated_Code/lin1.c
make: *** [Generated_Code/subdir.mk:91: Generated_Code/Cpu.o] Error 1
make: *** Waiting for unfinished jobs....
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@Generated_Code/dmaController1.args" -MMD -MP -MF"Generated_Code/dmaController1.d" -MT"Generated_Code/dmaController1.o" -o "Generated_Code/dmaController1.o" "../Generated_Code/dmaController1.c"
arm-none-eabi-gcc "@Generated_Code/lin1.args" -MMD -MP -MF"Generated_Code/lin1.d" -MT"Generated_Code/lin1.o" -o "Generated_Code/lin1.o" "../Generated_Code/lin1.c"
make: *** [Generated_Code/subdir.mk:99: Generated_Code/clockMan1.o] Error 1
                 from ../Generated_Code/dmaController1.h:83,
                 from ../Generated_Code/dmaController1.c:49:
make: *** [Generated_Code/subdir.mk:107: Generated_Code/dmaController1.o] Error 1
Finished building: ../Generated_Code/lin1.c
